Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
06.03.2005, 05:53 PM
Thanks for all your replies so far guys:-). Well, I'd be running this is my Dagger, but don't worry, it is not any ordinary Dagger (I don't know if you remember Cold Fusion that I showed a while back? That's the one, but she's progressed and improved much further since then). I won't go in to details, but it should be able to handle that kind of power...she could take it.
The reason why I want to go more this powerful is that my Dagger is big, and comparatively heavy (it will be around 4.5kg fully laden). I was orginally planning a pair of 8S motors on 8 cells each (16 total), but I think the rear motor would struggle a lot on acceleration. When the Dag acellearates, most of the load goes on the rear motor and I think it would have trouble. This is why I'm looking in to the "L" size motors. And I can't run only 1 motor as I'd lose 4WD, which I want to keep. Lastly, my custom chassis can't carry more than 16 cells, that is it's limit.
Yep, I plan to run a pair of 9L's or 10L's. If the amp draw would be too much with the 9L's then 10L's with 16 cells wouldn't be a problem for me to do. If Promod runs a pair of 7S motors, then that's 186A, so surely my 16 cells could handle 120A? Correct me if I'm wrong, though.
Thanks for all your help...:D
