Thread: Bl Tc4
mpetrich
06.04.2005, 11:15 AM
Hi Mike,
I have a small problem. I figured out how to complete the programming for the MGM 120. I put it in CAR mode and am using all of the default parameters. This is working fine with the nine cell battery. When I switch to the seven cell and turn on the ESC, it turns on fine, beeps once (like it should) and when I give it throttle everything works great. As soon as put the throttle back into neutral and try to accelerate again, the ESC and the motor do not respond. Nothing happens. I tried reprogramming with the seven cell attached and that didn't help. I have been messing around with the timing (setting it as low as possible), the time to accelerate (lengthened it to possibly reduce AMP draw) and even the throttle neutral setting (upped that parameter) and still nothing works. If I put the nine cell back in, everything works fine. Any ideas?!
Thanks,
Matt
Sponsored by Fusion Batteries
Associated RC10T4
Associated TC4
HB Lightning Pro II Converted
