Originally Posted by BrianG
Yeah, that looks like it could work nicely! :027: The only thing to remember is to adjust the support when you adjust the mesh, but that's no biggie. I'd probably add a thin layer of foam or some type of cushion to keep from scratching the motor, but that's easy to do.
You haven't by any chance made a stronger mount did you? I mean the longer parts that go over to the bulkhead ends and supports the stock pivot point. It seems to be made of pot-metal or something.
What about making them from plastic (delrin...)
You can set it once and then set gear mesh with swing arm, like with Nitro.
No, I didn't. Do they fail?
Artur
