Cartwheels
12.29.2006, 02:11 AM
http://www.castlecreations.com/suppo...er%20Guide.pdf
Couple of things. Are you turning on your transmitter first? The second set of beeps is when the tx/rx are both on, it beeps to let you know it is armed. If you are still having problems you should try to reprogram the esc. Do you have fresh batteries in your tx. Hope this helps, good luck.
