12.29.2006, 05:58 AM
Yeah, i am using integy aluminum diffhousings and Maxximizer 7075 cups, and they are a good combination. I am not surprised the diffs handle a dual setup. Some maintenance is required every now and then (check the bearings, adjust the gearmesh, relube with fresh lube. But all and all, i am not disappointed in the stock gears at all. Too bad you can't run silicone oil in them..
BTW a spool is a nono. On high speeds the truck will be far from stable.
