makes sense
ncalenda
Need for Speed
ncalenda's Avatar
makes sense - 12.30.2006, 02:47 AM
Originally Posted by BrianG
Most ESCs these days require you to remove the red wire in the throttle cable some way or another, like in the diagram in your link. The BK warriors are one of the few that give you the ability to disable the BEC with a jumper so you don't need to remove the red wire in the throttle cable. It won't hurt anything if you do remove the red wire though.
This is perfect, I was going to remove the red wire, but now I see, I can simply remove the black jumper instead.
Thanks!!
  Send a message via AIM to ncalenda
