01.04.2007, 03:44 PM
I'd like to get a hold of one of those to see if it could be easily modded (any donors? :)). Since it goes into full forward when triggered, it simply puts out 2ms signal pulses to the ESC telling to go full bore. If an adjustment was added to reduce this to 1.5ms, it would go to neutral instead. You could also set it to put out 1ms pulses instead so it goes full brake instead too...
