servo saver
HotnCold
HotnCold's Avatar
servo saver - 01.27.2005, 02:15 PM
a servo saver is a link between your servo and your steering linkage - ( usually plastic ) the servo saver takes all the hard impacts and ( with internal spring type movement ) keeps the servo from stripping its internal gears - hard to describe what it does in words - but you definately need to have one or you will definately do in your servo - metal gear or not -
Hows that "Hope and Change" working out for Ya???
