Thread: evx and lipo
GriffinRU
01.06.2007, 09:17 PM
Originally Posted by turbo4
I just ordered a lipo shield from dimension eng. I want to hook it up as you did. What is the best way to make the actual connection. Your diagram shows where to make, but Im looking for how to make? I cant tell from the other photo. Should I just pull back some of the cover and solder right in?
Thanks.
I will agree with Leroy it is up to you.
- cut heatshrink and unsolder wire from W.S.Deans connector
- put new heatshrink
- resolder wire back to connector with LVC wire
- melt the heatshrink
Repeat the same for other side...
Artur
P.S. It is possible to do that inside EVX, let me know if you want to do that, will look cleaner...
