jhautz
jhautz's Avatar
01.08.2007, 02:24 AM
Originally Posted by Cheater
Any more testing with the outrunner yet? Can't wait to hear how the little motor does!:027:
I havent spent any time running the buggy on the outrunner since the last testing. I have been running it on a Quark 80 and a Neu 1515/2.5D. I took it up to the local track and ran a few packs thought it. No problems with the motor ESC combo. Actually ran very cool. (of course it was only 45 degrees) But no heat isses at all. I was just testing out the rest of the build and seing how it all held up and handled. With the holidays and all I havent had much chance on the weekends to get out and run it again.
I wound up spending the last couple weeks revising some of my mounting. The esc mount I put in to test the Quark 80B wasnt quite up to snuff and I needed to make an aluminum and CF mount that would be more permanant than the zip ties I was using before taking it out again.
All in all It ran nice on the track. Needed to make some setup changes. I was running to stiff on the springs and shock oil so I lightened them up. Hopefully this help handleing the bumpy stuff. Flew straight and it was really fast. Had a small crowd around it in the pit. They acted like the had never seen a brushless 1/8 (they hadn't :D ) Then when it ran I had quite an audience. Thats when it really sucks to be as bad a driver as I am. Quite embarasing.:dft001:
Had one of the local hot shot drivers offer me $1000 for it on the spot. I told him that 1000 wouldnt cover it. But I would help him build one if he wanted to. (doing my part to suck more people in):018:
Next time I run I will test it with the outrunner again to see how she runs on the track. Hopefully in the next couple weeks. I've been more worried about the mounting and chassis setup to this point.
Originally Posted by Serum
Don't expect too much of it. An outrunner is not suited for the constant variety in RPM's a car puts it thru. the moving mass is simple too far away from the center and the wires are relative thin.
Far from ideal.
Actually Serum, the little that I did run it I was surprised at how good it felt and the power it generated. Like I said. A little different feeling with slower spool up, and weak motor braking, but good enough that I am interested to see what it does on a track.
There was another guy there that was running the Cyclon Car 5000 outrunner motor on the Quark 65 in his T4. He liked it. He said it had nice feel and smoother power than the other brushless motors he was running.
Side note: Sent the burnt MM in to CC just before X-mas per their customer service department directions. Still havent heard anything from them. Hopefully soon.
to make it...
or break it...
Silent...But Deadly
