Originally Posted by t-maxxracer32
so many confuysing terms.
i would be running 3s1p 2300mah in my bl rusty so how long should i take to charge it?
It depends on the charge method and amps. If you charge in series (1P) then the CCCV method will take 15 minutes at 10 AMPS. If you charge in parrallel (2P) then the charge will take twice as long (30 min) It will take 3 times as long using 3P & 4 times at 4P and so on.
