Promod
01.08.2007, 10:18 AM
Sylvester, never really checked into an LVC. Always just keep checking the pack with a volt meter.
Serum, the packs on maxamps site says "New 20C MaxAmps Lipo 8000HV 4S2P 14.8V Pack"
8000mah Capacity
14.8 Volts
44mm X 137mm X 50mm
20C Constant(160 amps)
30C Sustained(240 amps)
50C Burst(400 amps)
725 grams
Comes with Apache/Hyperion Taps
Not sure if these are the new 50C cells you are talking about. Please excuse me, I'm a little behind on some of the new stuff.
Captain harlock,better cells would make it go faster thats for sure. A motor with a higher KV than the 2240/10 should be faster too on 4S.(if the cells can keep up).
Thank you,
Promod
