lxmuff
lxmuff's Avatar
01.09.2007, 12:55 PM
What are these thermo pads breaking loose? I have a problem with mine that could same problem.
Originally Posted by BrianG
Just my opinion here, but the MM is not intended for a MT or similarly weighted vehicle. Plus, it's only good for 4s/12 cells despite some people running more. A full size ESC has more voltage options. The real answer here is to wait for the Mamba Monster Max... if it ever comes out!
BTW: If you attach an external heatsink to the Quark, it doesn't need a fan. But, you are right about the thermal pads on the inside breaking loose sometimes. That didn't happen to me, but I modded it anyway before it happened. The good news here is if that does happen, you can send it back to Quark under warranty.
