01.10.2007, 11:27 AM
If it fits, then cool! As long as you have about 75mm from the mount to the obstruction, and you can route the wires to they aren't in the way, you should be all set.
I think the concern came from the fact that the Lehner basic motor he's using is 48mm long and had so little extra room. It only makes sense that a 74mm motor wouldn't fit unless the motor was mounted in such a way to keep the wires clear of the obstruction.
