revopqrs
uhhh-huh!
revopqrs's Avatar
01.10.2007, 11:54 PM
well right now im running either some 7 cell 1500mah packs i put together, or 6 cell 3000mah for longer run times. i know they arent the best, but im kinda holding off on dumping loot into batts untill i know what kind of motor im going to run.
its been a struggle... do i buy batts first or a motor? if i go brushless lipos could happen i suppose.. or not...
i have no idea!!!
so thats why im here, im hoping the good people of this site can point me in the right direction.:027:
the way my brushless set up was in my mini lst, i expect alot from a system that costs twice as much... ya know what i mean? if i cant get that then i might as well cheap out and get the dual 700 set up... its like $xx(cheap) for everything. but its still kinda slow, not as bad as it is now tho! then i would buy the most battery i could get for the application.
is that logical?
what advise do you have for me? would the brushless set up dominate the dual 700s?
how about packs, will 14 cells do the trick? or will i need lipoly?
