gorillamaxx
gorillamaxx's Avatar
01.28.2005, 02:20 AM
The spacer is a good idea. We use to include spacers but discovered that most people preferred to use the rubber grommets that come with aftermarket servos. If you have these they would take care of it.
It looks like you could also shift the packs to the back cell spot on the chassis and avoid the servo (run the strap through the slot 2 spots back from the front for a tight fit)
