neweuser
neweuser's Avatar
01.11.2007, 03:03 PM
Originally Posted by burnsomenitro
Do the FLM combo bulks have the diff cases built into them? Where are these 1/8 scale diffs?
Yes the cases are built in. And the strobe comes with everything you need except the pressure plate and stuff. It comes with the bearing and all that, see the description for that you need, there are also directions stickied. This is your best bet!
the 9920 or MM with an 8xl will be good. A 9xl, you would have to over gear it to get speed, a 7xl IMO gets less run time than the 8xl, and the 8xl should run cooler.
