01.11.2007, 05:33 PM
Like I said, the 8XL will be good if you don't run it at that speed all the time. If you do plan to run max speed a lot, then a 9XL or 10XL would be a better choice. You generally want your motor to hit a max rpm of about 30k-35k rpm for best efficiency.
