coolhandcountry
coolhandcountry's Avatar
01.14.2007, 01:50 PM
Well test 3 was failure.
The spektrum has a bad habit of fail safe going back to the stock settings.
Stock settings cause the bk to hit wide open reverse for a split sec.
It did fine on the 9s but 12s is bad.
I had it all hooked up and no smoke which was good.
I turend the switch on and it went wide open reverse.
The motor spun up so fast the tires wouldn't keep up.
It took all the teeth right off the spur.
The tires was not on ground. I have to fix spektrum problem first.
