Compliantguy
06.12.2005, 02:45 PM
I'm still running the factory diffs.
I just started running 14 cells (3800mAh Intellect), and they absolutely KICK BUTT!! I couldn't believe the difference between my two 6 cell EPIC packs and my new two 7 cell Intellects! It will flip completely over if you hit full throttle from a dead start! It truly is a wild beast.:D
The pinion is a 14T and works perfect.
The Strobe kit is pretty cool, but I'm going to have to shorten the tension spring a little. Also, they should've included the spacer shims that are required during installation. It puzzles me as to why they didn't include them??:C: Luckily, I had some shims left over from my Nitro RC days.
Overall, I'm very impressed with the results from my latest modifications!
