rchippie
rchippie's Avatar
06.12.2005, 06:49 PM
The best way to put a flat spot on the shaft in my opinion is to take a pair of needel nose pliers put a peice of a rag around the shaft against the end of the can grip it with the pliers. Then take your dremal and make your flat spot. The flat spot only needs to be about 1/16 -1/8 wide and about half the lentgh of the shaft.
REAL MEN RUN BRUSHLESS
