01.15.2007, 01:00 AM
Well, according to the 125B manual:
Originally Posted by Sky-Technology.com Website
6.0 Product Warranty
Sky & Technology Co., LTD warrants products to be free from defects in materials or workmanship for a period of 180 days from the original date of purchase (needs to be verified with a dated sales receipt). This warranty does not cover the following: incorrect or erroneous installation, any component parts damaged by use or modification, damage or tampering to case and/or any exposed circuit boards, overloading specified voltage, short circuiting from spliced or damaged wiring and/or motor (i.e. incorrect screw lengths), reverse battery polarization, overheating solder tabs, damage from improper installation of FET servo or receiver battery pack, using a Schottky diode, splices to wires (i.e. ON/OFF switch) causing a short circuit, damage from force when using Programming button, tampering with the internal circuit components and/or disassembling case, water, moisture or any other foreign objects to enter ESC or get onto the PC board, permitting exposed wiring or solder tabs to short-circuit, fitting connectors which are incapable of handling the specified current loads and/or connectors that provide poor electrical current and causes controller to function and operate defectively and/or inconsistently or any damage caused by a crash, or flooding.
Sky & Technology Co., LTD reserves the right to change or modify this warranty without notice.
