Thread: mf2 or rusty?
crazyjr
crazyjr's Avatar
01.15.2007, 03:01 AM
If thats in a rustler, you may be undergeared. The rustler has a 2.72 transmission ratio, where the T4 is 2.60. I think if you put a 20 tooth pinion on it, it will wake up. If its running hot you might lose a little heat as well. In my T4, it would run 164 motor and 163 ESC on avarage with a 14 84 gearing, Going to an 18 it droped a little heat.
