01.15.2007, 03:19 AM
If you went with the 7XL, you should use a smaller pinion gear. The 7XL would allow you to go faster without necessarily sacrificing acceleration, but you would be sacrificing runtime.
The best way to get more speed is by using higher voltage. How many cells are you currently using?
