Originally Posted by jollyjumper
is it the ring and pinion? if not=> if your in sand only, i'd try a spool first.
if its the ring and pinion you'll need 1/8th diffs.
When I opened up the diff, the 2 small gears were missing teeth, the pinion gear was fine.
