06.13.2005, 12:00 PM
Welcome to the forum!
drop a few teeth on the pinion. that's the solution!
The reason it is done with the 2nd gear is simple;
The goal was to loose weight, and when it's locked in 1st, you are not able to drop one halve of the transmission, or you need to make a special upper driveshaft, or modify the topshaft.
