01.16.2007, 02:41 PM
IMO for racing standad size work better because of the less tire you get more turning and it does not slide as much in the turns as the 40 series. But for bashing and looking cool go with the 40 series IMO because it puts more tire to the ground and it looks cool (that is if your motor can support 40 series but it probably can for example the novak gus recommend not using 40 seirs because there motor will not push it but pretty much any other motor will be able to handle it).
