Originally Posted by BrianG
@Crazyjr: You did mention some cogging on the 9XL. Did you by any chance mess around with the tioming and punch control? Those two settings should ease up on the ESC a little and should eliminate the little cogging you had. Just and idea...
No i haven't yet, everything is in default except for the cut-off. I was trying to make it sweat to see if it could handle all the torture, I am very impressed.
I was running an 18 tooth pinion and thought i might have it overgeared, I'm going to a 16 and 5s and see how it runs. I will play with the settings and see what it will do. I do wish the V2 slipperential comes soon, wheelies are boring to a racer. The lipo's are amazing, i spent over 3/4 of the charge and got the fastest speed at the end of my run, that was with 2 2s 8000mah maxamps lipo's
Hey BrianG, how do you have you 10XL geared on 14 cells
