Originally Posted by Serum
the most important thing is how and how fast the fetts hit the full conduction. total losses will be way more than .5 W. It's very hard to get the high frequency switch on/off process to be 100 percent clean .. (but i don't really need to tell you that.. ) :p
Yeah, I tried to mention that too, but it's hard to picture if you don't see a waveform and/or understand what causes heat. Not too many people know what slew rate is. So I didn't spend too much time on the topic. Basically, I was comparing the MM specs to the R1 Pro spec outlining the substantial difference in the resistance since those are noticeable numbers.
And yes, the higher the switching frequency, the harder it is to get a perfect square wave.
