01.20.2007, 04:59 AM
I actually saw this over at the Traxxas forum (because it was kinda slow here), but thought I'd link the actual source.
One thing these numbers don't show is the power curve. Any amount of power is not much use if peaks at the end of the RPM range...
Someone should get their BL setup on that dyno! And even hook up an eagletree to see how much HP in vs HP out (efficiency). This would also show if the dyno is relatively accurate.
