Originally Posted by captain harlock
I usually hardwire the controller's wires to the 3.5 connectors of the 19 series. It's much better using it than those blood seething connectors.
You mean just sloder the wires into the 3.5mm sockets on the back of the non-high amp version of the 1940 motor? I thought about doing it but I was afraid of melting a connection inside the motor or something and causing other problems. If you have done this can you post a picture? I have been wondering if this would work, but have been to chicken to try it yet. Plus once you try soldering it directly to the 3.5mm sockets getting all of the solder out again so the 3.5mm plug would work properly is not likely so there is no turning back once you do it.
If someone has proven this works without melting something else in the soldering process I'm gonna do it. I hate the 3.5mm sockets.:mad:1
