01.21.2007, 08:02 AM
I'm very sorry I did not respond faster, my friend Jeff.
Yes, I've soldered the soket plugs to the wires directly and it worked perfectly. I used the 1920/8 stock can, but I prefer the hi-amp like the 1950/10 I have where soldering is much easier. You need a soldering iron of atlease 60W if you need clean and fast soldering with a chesil tip for fast heat transfer. Using a soldering iron without the chisel tip even if it was 100w strong, is gonna cause a SCHIZOPHRENIC MELTING!!! where part of the solder is successfully molten in one place and the other part did not.
Hayden, is that an HPI touring car?
What speeds have you achieved?
Nice to meet you!
