01.21.2007, 09:42 AM
I talked to hippie on phone. The buggy he used to run was geared lower than
the buggy with problem. Higher gearing more amp draw more heat. Yes the
fan helps cool the esc but it is still cooling while you are trying to get temp gun
and a temp reading. He can't drop the gearing for way the buggy is set up.
Well he can but it is not easy or cheap. How else could one tell if it is a
thermal problem if you can't change gearing?
Peace!
Country
Help support the
Rc-Monster
Buy here
