01.22.2007, 05:52 PM
What ofna buggy is this about?
most Ofna buggies use a steel spur, which can be replaced by a 51T plastic one.
if the diffs are 43/13 (3.308:1 ratio) If you used a 51T spur and a 12T pinion, you have got an end ratio of 1:14. I would not use a 10T pinion, they tend to wear fast.
