01.22.2007, 08:26 PM
Cant we all just get along :005: .
Okay here i go my first setup was as follows MM controller with 7XL with 14 3800 cells & a 13/46 gear or a ( 3.6) ratio with ubec. & fan. After about 5-6 min of running it would just stop. By the time i got of the drivers stand & got my car back to the pit table & temped the speedo it was 140 & was working again.
Set up #2 was same as above except for the ubec was replaced with a reciver pack. It did the same thing.
My MBX4 buggy that rene owns know used a 7XL on the same cells but had a 12/51 gear or a (4.25) ratio & a warrior 9920 had know issues what so ever.
After talking to leroy & jeremy on the phone i think it's over geared.
Jeremy orderd some century haredned pinions from tower for his crawler. He's going to let me borrow the 11t pinion so i can try it in my buggy to see if it is the gearing causing the issues im having. This pinion will give me a ( 4.1 ratio) which is a lot closer the ( 4.2 ratio) i had in my mbx 4 with the same motor.
