sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.22.2007, 10:31 PM
Originally Posted by BrianG
In this pic, it looks like the plastic diff holder is not fully seated all the way down on the metal spacer thingies (that's a technical term BTW :)). Or does it just look that way?
It just looks that way. There are some plastic "thingies" :005: that go under the holder that keep the brake discs separated. That's just the ridge where they seat. It's all they way down. :)
Oh, and I agree with MM; put some screws on the bottom piece...
Yup, there are, you just can't see 'em.
Nice mount BTW!
Thank you SIR! I've seen so much good work on this site, I knew I had to do good to keep up, haha!
Oh, and I gave it a shot on 12 cells today:
Very much a quick rig-up proof of concept job. It works, and works darn good. Limited space (and sight distance at night) so I wasn't able to run it much. The Mamba Max and the motor were just warm, no heat problems at all. The motor was slightly hotter, so I can probably go up a few teeth. It's a hoot to drive, crazy acceleration. I need to get my road rage tires mounted up before I destroy these panthers!
Sleeb
