turbo4
turbo4's Avatar
01.22.2007, 11:09 PM
I don't know how that lvc works.
I have had a lvc go wide open reverse on me.
Well the batts are 7.4 at stand still. But with load could fall to 6v.
You were running lipos on the evx wernt you? Did you not use a lvc? Anyhow I ran the truck some more with the starting voltage at 7.6 and ran it to 7.2v. No reverse experiences this time. I did get a lot of stuttering at a stand still then wide open throttle. I assume this is an overdraw of current that the batts cannot supply?
