Thread: Gearing help
Aragon
01.23.2007, 04:29 PM
Originally Posted by Sedri
Aragon, I have no idea what end result you are after
I am after maximum efficiency.
I set up an MP 7.5 with 43/13 diffs, 44/16 center gearing, and a 540XL 6T on 4S, and the buggy was just ridiculously fast and nearly uncontrollable; how in the world would 8S work? I was actually thinking of "tuning down" power a little by switching to a 9T 540L with 4S.
Your experience sounds correct. Both the setups you describe would have been capable of over 50 mph by my calculation...
On 8S, I don't know how your motor would ever see anything close to the ideal of full throttle...!
Yup, this is why I want to gear down to a controllable speed, but...
At first I was geared for a top speed of 45 mph with 14/46 center gearing, and the motor ran hot from being notoriously undergeared,
...maybe I have more to learn. That's interesting. Is this a common problem with all brushless systems? Is there anyway to calculate if this will occur with a setup before running it?
and full throttle was simply impossible without looping out and crashing. Simply not enough traction with that kind of torque/hp in a 7 1/2 pound chassis.
That I hope to work around ala MGM's programmable soft start. Is my thinking correct?
