GorillaMaxx360
GorillaMaxx360's Avatar
01.23.2007, 10:18 PM
Originally Posted by Mike.L
hey budd nice looking truck... i rember that i was just running grey bulks and rpm arms or tie hinge pins and was going at about 25+mph and seriously bent the hinge pin....with arms like flex tech and hybrids....they will bend like spaggeti..
has anyone thought about the jd carbon carbon pins?
I e-mailed Jd carbon because i was interesed in these but i realized they only make these for self retaining hinge pin cars(cars that use something on the end of the hige pin other than eclips to hold the hinge pins in place) that is because you could not fit an e clip on the carbon i guess it could be done but it probably wold not be as effecent it might weeken it ifact but if you could keep the pins on the arms somehow i hear these things are cheap, lighter than ti, and indestructable and they even have a warintee. Also guys should i expect to break hnge pins if i am not jumping anything over 5ft and just driving on the street and mild bashing (because i live in a nieghborhood not a lot of places to bash drive). should they hold.
