01.24.2007, 10:29 PM
To make the tranny fit is quite an easy task, you just have to machine like 1-2mm off the side and it will directly fit into the space, than some drilling in the chassis so the tranny will fit. Just a tip, when you have the tranny in place keep the dogbones in when you are marking the holes to drill in the chassis, its just so you know the dogbones are even on both ends.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
