Procharged5.0
Procharged5.0's Avatar
01.25.2007, 01:19 AM
The shaft is custom made from high strength steel. Several times stronger than stock. The Slipper is secured by a 5mm nyloc nut. Pins on the gears are solid hardened steel. I'll re-post the picture with the details/highlights. I need to reformat it first.
