MetalMan
MetalMan's Avatar
01.25.2007, 02:16 AM
I know the bearing hole isn't 10mm, I said if you drill it to 10mm you could use a 5x10mm bearing in the spur. The hole is almost 10mm though, so minimal drilling is required, decreasing the chances of the hole being drilled off-center.
I did this with the custom slipper clutch setup for my X-Terminator 1/8 buggy (Revo slipper clutch + MGT spur) so I know it works.
