Originally Posted by BrianG
I too am looking for the 1940, but 8 wind, so you're not alone! :)
I think the only difference between the hi-amp and regular is the construction. The regular ones let you switch between delta and wye, while the hi-amp motors are non-changeable for the least amount of resistance.
Doesn't the hi-amp use direct motor wires vs connectors?
