01.27.2007, 10:27 AM
I agree - the temps are a little low - adjust the high side needle in a touch and retemp - ( the high side adjustment needle is usually close to the carb inlet ) but find the diagram of the motor online - and check - adjust it only 1 hour at a time ( i mean if the screwdriver slot you adjust on the needle is facing up and down - that would be 12:00 - turn it clockwise 1 hour ( so its pointing at what would be 1:00 on a clock ) and retest it - only adjust after properly warming it up as well..
Hows that "Hope and Change" working out for Ya???
