tittelba
01.28.2007, 12:31 PM
I tried 100% this morning. It's not any better than the 60% setting, if not worse as it doesn't cut out any less but has even less punch then before.
Do you think the cause is my ESC or my battery/cable set-up? I'll move up to a beefier ESC if it'll fix the problem. I still can't beleive that 8000mah MaxAmp batteries couldn't keep up with the amp draw and I think my gearing is low enough.
Thanks,
Tom
