01.28.2007, 07:28 PM
Originally Posted by squeeforever
I would go with LiPo's to be honest. If your that worried about them, I would do some preventative measures that will ensure there safety. I have seen some companies put CF on the top and bottom. That should prevent alot of things that could happen. Another option is make some kind of box for them. There is a Revo around here somewhere that has a little box for LiPo's. It was made of 2 pieces of L profile aluminum and a small hinge (piano I believe he said) and lined with foam.
Some Lexan would be a good choice too. That way you could see if there was a cell starting to puff, or if the heatshrink gets melted like I saw from another user here (can't recall who ATM). But, won't encasing the packs reduce cooling efficiency because of no airflow?
