glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.28.2007, 09:41 PM
Guys were removing the gaskets??? Wouldn't that make the gear mesh worse? Hmmm...
Seems that you should add a couple gaskets to get clearance for the gears if they are tight.
I think you might have to sandwich the lexan gasket with the paper gaskets to keep it sealed tight.
So how close is your buggy to being alive???
