01.28.2007, 11:37 PM
Can you shave a little on the screw slots so the fit is right? I know you probably hate to do that but if it's pretty close I would do it. I've had to do that on my homemade ones more than once. ;)
Diff: what some have done is use some extra stock gaskets to shim the gear.... same thing you did with the lexan, but just using several gaskets. I'm not sure the lexan will seal well enough by itself, but if not it's no biggie to add a gasket.
Definitely get some pics, even if it's only ALMOST done, lol.
