01.29.2007, 12:07 AM
Originally Posted by glassdoctor
Can you shave a little on the screw slots so the fit is right? I know you probably hate to do that but if it's pretty close I would do it. I've had to do that on my homemade ones more than once. ;)
Diff: what some have done is use some extra stock gaskets to shim the gear.... same thing you did with the lexan, but just using several gaskets. I'm not sure the lexan will seal well enough by itself, but if not it's no biggie to add a gasket.
Definitely get some pics, even if it's only ALMOST done, lol.
When I first found out the slots weren't quite right, I was ready to do something like you suggested before I decided not to. I even had the dremel in my hand, but I got scared. :002: I'll see how the temps are with the 15T before I go ruin, I mean modify, Mike's motor mount. :) If I find I need to go to a 14T, I'll have to do the modification you suggested and hope for the best.
Where would I find these gaskets? Before I made the lexan one, I looked at Tower and saw these, but the screw holes on the one I made are VERY close to the edge of the diff compared to the pictures at Tower, so I didn't think they'd work. At any rate, I'll see if this works and go from there. Mike ought to carry some of those in the RCM store (hint hint ;)).
Right now, it doesn't look much different from pictures posted a month or so ago except for Mike's mount and the Neu mounted to it. By the time I do anything different, it'll be done anyway! So, you'll just have to wait. :) Besides, it's not like this is the first (nor the best) conversion on here...
Thanks for the suggestions!
