glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.29.2007, 02:55 PM
And when we are running 4s lipo we also are normally using a lower kv motor than you would on 2s or 3s. The end result is that the 4s setup is actually easier on the MM.
But as mentioned, you need to bypass the on-board bec to make it work.
